Cracked Exhaust Manifold. Where to begin?
Discussion in 'Restoration Projects & Questions' started by Billy Spitfire, Sep 18, 2016.
  1. Billy Spitfire
    Billy Spitfire New Hydrodyner
    Hydrodyne 110 Volvo/Penta 1965
    1965 Hydrodyne Volvo Penta AQ110. Cracked exhaust manifold, water spitting out of the outer rectangular shell. Where can I find a replacement part? Can it be welded?
  2. footndale
    footndale Established Hydrodyner
    Fremont, WI
    None
    Retired
    Short term you can use JB Weld. Heck, block engines have even been fixed by JB Weld
  3. Billy Spitfire
    Thanks, about half of my friends say do it, and the other half say no way! My dilemma is that the exhaust manifold appears to have a round tube inside a rectangular shell, all cast, but water was spurting through the outer shell. Cracked in the middle. Don't know if the inner and outer are both cracked or just the outer.
  4. tj309
    Try taking the manifold in to a competent welder. I had a cracked manifold once and I did that and the welder said that since it was made out of iron he couldn't guarantee it. My other choice was to buy a new one so I had nothing to lose and he fixed it perfectly.
  5. Anthony
    Anthony New Hydrodyner
    Kelowna bc Canada
    1968 hydrodyne
    I have a set if you want
  6. engineerMich
    engineerMich New Hydrodyner
    19964 Hydrodyne
    I had a crack just like you show. A good local shop welded it up, and I have had no further problems. I say try it!
  7. oldskier
    oldskier Established Hydrodyner
    East Tennessee
    197? Hydrodyne 18 I-O
    Mine is welded also. A good welder will tell you it may not work but it has many times. They use a special welding rod with high nickel content I believe. My guy said it may drip a little but it is dry as a bone. There is little or no stress on the weld, just water flowing behind it so I think thats why it generally works.
