Engine and Outdrive
Discussion in 'Restoration Projects & Questions' started by lccovers0427, Sep 1, 2014.
  1. lccovers0427
    lccovers0427 New Hydrodyner
    64 Runabout
    Hi to all! New to the site after buying a 64 -65 to restore to its glory.
    Mine has the V8 Interceptor and the Eaton outdrive. The Eaton needs all new gaskets and some prop parts.
    I have access to a Volvo Outdrive that seems to be in better condition. I believe that is a 69. Which one of the two is better and are parts easier to find for either. Would the Volvo fit on my 64-65?
    Possibly, but you need to be much more specific in your description of the engine and drives. I would use pictures and model numbers. Then I would google this subject and you may find the answer. I do know that the volvo need to be a V-8 model for the correct ratio.
    If I were doing that job, I would look for a junk boat with a complete mercruiser and modify the transom for it. That would give you everything you need and parts are plentiful.
  3. glenn
    glenn New Hydrodyner
    Thompson Chris craft 1963?
    If you do elect to swap that out drive I would be interested it the Eaton depending on the model. If you do, please share the Eaton serial number. Please don't just junk it.
  4. lccovers0427
    64 Runabout
    Thanks, I will let you know
