Hydrodyners.com
Hydrodyners Store
Forum Home
* Login   * Register * FAQ    * Search
It is currently Mon Sep 06, 2010 10:13 pm
Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2, 3
Author Message
 Post subject: Re: Trailers
PostPosted: Wed Nov 04, 2009 5:30 am
Offline
King Dyner
King Dyner
Boat Model and Year: 77 Dyne 18
State or Country: FL
Mark,
If you look closely at the backing plate, there should be a rubber plug that you can remove to slip a screw driver or a brake adjusting tool in to adjust the brakes from the outside.
When you re-assemble the system, write down which way the adjuster go to tighten, so there is no guess work later. I always forget.
I don't think it is recommended, but I put a little anti-seize on the threads of the adjuster to keep it from rusting and seizing. Just a little, not enough to get on the brake shoes.
You might be able to use that access to flush out the salt at the end of the season.
I doubt that the stainless stuff is worth it.
edit: There is a marine galvanized version:
http://www.trailerandtruckparts.com/Gal ... p_486.html
jim
Top
 Profile
PostPosted: Wed Nov 04, 2009 6:43 am
Offline
King Dyner
King Dyner
Boat Model and Year: 1971 Baby Dyne
State or Country: MN
Ski Team: TwinCities RiverRats
I was just going to mention all the stuff that Jim just said (access hole, galvanized version, anti-sieze on the adjuster) but was actually interested in the stainless version. I don't like the stainless and aluminum combination though.
_________________
Keep yer Uptown outta my Nordeast
Top
 Profile E-mail
PostPosted: Wed Nov 04, 2009 11:08 am
Offline
Hydrodyners Admin
Hydrodyners Admin
User avatar
Boat Model and Year: 1973 Hydrodyne 18 w/Twin 1150 Mercs
State or Country: CA
Ski Team: None
I have found that if you need to flush the drums (I have too on my travel trailer since it gets into the mud and sand) I cut off about 3/4" from the lower section on the backing plate. That allows Dirt and muck to be flushed out with out the pain of removing the whole drum.
Daniel
_________________
2MERCS "On the license Plate, and on the back of the boat!"
Top
 Profile E-mail
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 1 guest
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
cron
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
[ Time : 0.096s | 20 Queries | GZIP : On ]
