1972 Keel Up Restoration
Discussion in 'Restoration Projects & Questions' started by tj309, Sep 4, 2013.
  1. jim
    The marine stuff is pretty tough.
  2. tj309
    The fill and vent were placed way up front as per my specification. I do know that it would be hard to replace hardware way up front under the deck once the deck is permanantly mounted but I figgured this restoration should last 30 years. After 30 years I probably will not be around and who would do a 3rd restoration on a 75 year old boat?
  3. stoneykegonsa
    stoneykegonsa Hydrodyner
    Mcfarland Wi.
    3dynes 1969 125merc 1972 888io 1976 150 bmax
    Who made the tank how much?
  4. stoneykegonsa
    Mcfarland Wi.
    I found the info.
  5. tj309
    2 days of work - here is day 1: 20150521_172336_001.jpg 20150521_164447.jpg
  6. tj309
    20150521_164518.jpg I am doing this from my phone so it's a little more difficult. I glassed the Bow shelf prior to installing the tank. then I started on some electrical work: 20150521_164435.jpg the white thing is a GPS antenna. I also glassed some thin pieces of plywood to the bottom of the motor well and this is where the rigging hoses will attach:
  7. tj309
    I will post day 2 work later
  8. tj309
    Day 2 we put the deck on to fit the motor well parts. 20150521_191900.jpg that piece is the one that had the 2 thin pieces of plywood glassed in in an earlier pic. The dark stuff around the edges is fiberglass jelly. Very useful for sealing cracks so they don't leak resin when tabbed in. the motor well base goes all the way forward to the front of the arch where it will be glassed in for structural integrity and also to help support the ski pole. this along with the transom and the sides of the splash well will make a box which should be very strong and with the three other knees I should have a bulletproof structure.
  9. tj309
    20150521_212541.jpg Then I cut and mounted the rear arch And tabbed in the bottom motor well piece. The wax paper is so the arch does not adhere to the motor well bottom.
  10. tj309
