Bow colors and pylon
Discussion in 'Questions/Comments' started by capt.craigw, Sep 21, 2014.
  1. jim
  2. Dennis
    Dennis Hydrodyner
    Eastern Shore of Maryland
    1989 Hydrodyne Comp
    Tuckahoe River
    Whatever year you have a very nice looking Hydrodyne that I bet performs very well.
  3. kevinb
    Craig:
    You definitely have a Hydrodyne 18 but they were produced through 1978 approx. A handful made beyond 1978, but yours looks to be the pre-1978.
    Nice rig even if it predates. BTW, where are the pics taken? I'm assuming out of the country by the numbers on the boat.
  4. capt.craigw
    capt.craigw Hydrodyner
    1985 18 ft skier
    Yes I'm from canada I bought the boat as a bare hull with no engine or seats. After installing the engine it ran terrible anything over 35 mph would create a bow wake, I couldn't get the bow out of the water at all. I raise the engine, had a 250 lb friend sit behind the pylon. I couldn't get it out of the water the spray would start before the drivers seat. So I took the deck off and removed the floor and replaced the transom at the same time and added a fuel tank under the bow. It was deffently barrel rolling, the floor consisted of 3/4 inch plywood no one section was bigger then 3 ft x 3 ft. As you can see now the bow lifts fine and it's a 60 mph boat now if you want it to be. Yes she's a fine boat now
    Did you change the shape of the aft deck and splashwell? I like it a lot.
  6. kevinb
    Welcome Capt.Craigw. And I thought WI was a short ski season (aka the Tundra). Was there false floor and stringers when you replaced or are you talking about replacing the Balsa-core which was the floor in the pre-1970 HD 18 hulls. I'm assuming the later. The answer will give some indication to the era of the hull.
    Get out of the water quick this time of year,
  7. dynebob1
    dynebob1 Boat of the Month
    Glen Ellyn, Illinois
    Craig,
    Like I said originally....your boat is a late 60's to 1978 18 footer. Looks like a fabricated rope guard (nice)
    and an aftermarket removable pylon. If you are looking for a factory pylon for that boat, try Pete at
    Dyna-Ski. I know he did have a few he pulled out of old 18's over the years. Probably won't be cheap, or
    inexpensive to ship due to its size.
    Bob
  8. jim
    I never saw an aft deck and splash-well like that on a 60 to 78.
  9. capt.craigw
    1985 18 ft skier
    Not sure about the floor if it was basa or plywood. It looked like plywood with carpet. The stringers were also replaced which didn't look much more then 2x4s. What was the false floor all about? The splash well is original the top of the rear deck is stamped nonskid from the factory .but I did put the upholstered cover cover to hide the battery and bilge pump.
  10. capt.craigw
    1985 18 ft skier
    Yes I'm from canada I bought the boat as a bare hull with no engine or seats. After installing the engine it ran terrible anything over 35 mph would create a bow wake, I couldn't get the bow out of the water at all. I raise the engine, had a 250 lb friend sit behind the pylon. I couldn't get it out of the water the spray would start before the drivers seat. So I took the deck off and removed the floor and replaced the transom at the same time. It was deffently barrel rolling, the floor consisted of 3/4 inch plywood no one section was bigger then 3 ft x 3 ft. As you can see now the bow lifts fine and it's a 60 mph boat now if you want it to be. Yes she's a fine boat now
